Attributes in Esri Mosaic Dataset
  • Jul 7, 2022 6:50 PM UTC
  • 159 views
Good day,
I'm using FME desktop to create a mosaic dataset of some imagery in a file geodatabase. In the footprint attribute table there are default fields "Name", "GroupName", and "ProductName" that are able to be edited in ArcGIS. Is it possible to write this data to the mosaic dataset in FME?
Right now I'm populating these attributes in an AttributeManager transformer, but they are obviously not being added to the mosaic. The "Name" field seems to be populated with the basename of the rasters I'm addingAttribute Table
I'm using FME Desktop 2021.0 with the ArcGIS Pro 2.8 data interoperability extension.
kailinatsafe
Forum|alt.badge.img+24
Hello @sabre2170​ , would you be able to share a sample workspace and what version of FME you're using? Best, Kailin
