Appending data from second Excel worksheet to the first one
jiro
Hi all,
I'm trying to merge two separate excel spreadsheets. Both worksheets have the same names and number of columns. However, they do not have a common primary key to perform a join. All I'm looking for is to append the contents of the second spreadsheet to the end of the first so that I have a single spreadsheet at the end.
How can we achieve this kind of merging without using the FME transforms inheriting from the SQL language (FeatureMerger or FeatureJoiner) in FME Desktop?
dustin
Forum|alt.badge.img+30
  • May 20, 2022
If both worksheets have the same schema (column names), then you really don't need to join or merge anything. Simply feed both Readers into a Excel Writer with the same schema, and all features entering the writer will be treated as a single output.image
jiro
  • May 20, 2022
Hi @ddbrocarto,
Thank you for your answer to my question. Yes, both Excel spreadsheets have the same schema. Surely there is no possibility to combine the two worksheets through a transformer without using joins... In my case, I have to go through some data processing steps such as filtering (tester), editing , searching and replacing strings and finally geocoding before the final result...
So I clearly understand that I need to input my two Excel spreadsheets into separate input reader ports and process all the steps before outputting the two Excel data schemas into one output. I think I understood the problem and the workflow. I will try it!
Thanks again @ddbrocato!
rudewi
Participant
  • Participant
  • May 24, 2022
you can also use a junction to do this appending anywhere in your workspace
jiro
  • May 24, 2022
Hi @ddbrocato and @rudewi,
Thank you again @ddbrocato for your help. I've successfully completed my workflow with the method you advise me and it's work fine. See attach my FME Desktop workflow.
@rudewi I'll try to append the data worksheet using junction. I've never tried this before.
Regards,
