Anybody have tips to update my python code to python 3?
  • November 9, 2018
  • 389 views
johnglick
Forum|alt.badge.img+3
Hi, my python code below does not work in python 3, I receive a " Unicode-objects must be encoded before hashing" error message. Any tips?
import sys, getopt, hashlib, os
from hashlib import sha1
import hmac
import base64
import time
import requests
import subprocess
import json
import fme
import fmeobjects
import datetime
def calculate_signature(feature):
# get input values from feature attributes
api_key = FME_MacroValues['API']
host = feature.getAttribute('host')
method = feature.getAttribute('method')
shared_secret = FME_MacroValues['SharedSecret']
timestamp = feature.getAttribute('timestamp')
#timestamp = datetime.datetime.utcnow()
url = feature.getAttribute('url')
# set access_key
#access_key = FME_MacroValues['AccessKey']
access_key = 'A0F66A0E-0CC9-7ABE-24CC-F8807E2829AB'
# copied code from calcualte_signature
sig_block = "{}\\r\\n{}\\r\\n{}\\r\\n{}\\r\\n{}\\r\\n{}\\r\\n".format(
method.upper(),
host,
url.lower(),
timestamp,
api_key,
access_key)
print("\\n\\n -- sig block -- \\n" + sig_block + "\\n\\n")
decoded_secret = base64.b64decode(shared_secret)
hashed = hmac.new(decoded_secret, sig_block, sha1)
sig = hashed.digest().encode("base64").rstrip('\\n')
# add sig value to feature as attribute
feature.setAttribute('sig',sig)
#feature.setAttribute('timestamp',str(timestamp))
Hi @johnglick,
Perhaps you might find it useful to use 2to3 - a python tool to automate code translation: https://docs.python.org/2/library/2to3.html
Else this doc may also be helpful to you: https://docs.python.org/3/howto/pyporting.html
  • November 10, 2018
Probably you will have to modify these two lines.
Python 2.7
sig = hashed.digest().encode("base64").rstrip('\n')
Python 3.x
hashed = hmac.new(decoded_secret, sig_block.encode(), sha1)
sig = base64.b64encode(hashed.digest()).decode('utf-8')
johnglick
  • November 11, 2018
Python 2.7
Python 3.x
works perfectly thanks!
