What are all the files that specify the FME Server hostname, that can't be accessed from the FME Server Web UI or backend database?
What are all the FME Server config files where the hostname is listed?
Best answer by rylanatsafe
With great knowledge, comes great responsibility. Edit these files at your own risk!
This information has been gathered from an FME Server 2017.1 installation.
<FMEServer_Install>\\Clients\\FMEServerConsole\\FMEServerConsoleConfig.txt <FMEServer_Install>\\Clients\\utilities\\addCleanupTasks.bat <FMEServer_Install>\\Clients\\utilities\\addPublishers.bat <FMEServer_Install>\\Clients\\utilities\\addServices.bat <FMEServer_Install>\\Clients\\utilities\\addSubscribers.bat <FMEServer_Install>\\Clients\\utilities\\configureDemoWorkspaces.bat <FMEServer_Install>\\Clients\\utilities\\serviceWorkspaceDefs.xml <FMEServer_Install>\\Clients\\utilities\\serviceWorkspaceDefs_old.xml
<FMEServer_Install>\\Server\\fmeCommonConfig.txt
<FMEServer_Install>\\Server\\fmeServerConfig.txt
<FMEServer_Install>\\Server\\fmeWebSocketConfig.txt <FMEServer_Install>\\Server\\processMonitorConfigCore.txt
<FMEServer_Install>\\Server\\processMonitorConfigEngines.txt
And,... these files reference "localhost" in some (or most) FME Server installations.
<FMEServer_Install>\\Utilities\\tomcat\\webapps\\fmeaws\\WEB-INF\\conf\\propertiesFile.properties <FMEServer_Install>\\Utilities\\tomcat\\webapps\\fmedatadownload\\WEB-INF\\conf\\propertiesFile.properties <FMEServer_Install>\\Utilities\\tomcat\\webapps\\fmedatastreaming\\WEB-INF\\conf\\propertiesFile.properties <FMEServer_Install>\\Utilities\\tomcat\\webapps\\fmedataupload\\WEB-INF\\conf\\propertiesFile.properties <FMEServer_Install>\\Utilities\\tomcat\\webapps\\fmejobsubmitter\\WEB-INF\\conf\\propertiesFile.properties <FMEServer_Install>\\Utilities\\tomcat\\webapps\\fmekmllink\\WEB-INF\\conf\\propertiesFile.properties <FMEServer_Install>\\Utilities\\tomcat\\webapps\\fmenotification\\WEB-INF\\conf\\propertiesFile.properties <FMEServer_Install>\\Utilities\\tomcat\\webapps\\fmeoauth\\WEB-INF\\conf\\propertiesFile.properties <FMEServer_Install>\\Utilities\\tomcat\\webapps\\fmerest\\WEB-INF\\conf\\propertiesFile.properties <FMEServer_Install>\\Utilities\\tomcat\\webapps\\fmeserver\\WEB-INF\\conf\\propertiesFile.properties <FMEServer_Install>\\Utilities\\tomcat\\webapps\\fmetoken\\WEB-INF\\conf\\propertiesFile.properties
