How to get the percentage of a feature compared to another ?
For exemple, I would like to have "This feature A overlaps 5% of the feature B" and "The feature B overlaps 30% of the feature A" (I have one dataset)
For now, I used "AreaOnAreaOverLayer" to have overlaps. Then, I calculated the area of the overlaps and the features to know what part of the feature the overlap represents.
However, at the end, I have for a feature the percentage that represents the overlap compared to one feature, but I haven't the other feature. I only have " Field 1: Feature A / Field 2: 80%" . That's all
I want another field that tell me the name of the other feature.
Thank you for helping
Best answer by markatsafe
@lachichi_farah​ thanks for including the same data. that makes it much easy to test out a solution. Attached is an example workspace that I think more or less will give you what you want. (FME 2022.1)
danilo_fme
Forum|alt.badge.img+42
Hi @lachichi_farah​
Did you choose the configuration Merge Incoming Attributes ( into transformer )?
Thanks in Advance,
Danilo
danilo_fme wrote:
Hi @lachichi_farah​
Thanks in Advance,
Danilo
I've just tried but I think it doesn't change anything
Forum|alt.badge.img+32
  • July 20, 2022
You need to build a list in the AreaOnAreaOverlayer, then explode this list so that you can do the overlap sums for each feature. Something like this
I'm going to test. Thank you!
So I tested it but it doesn't work...or I did it wrong
I haven't in the same line the names of the two features which overlaps
  • July 20, 2022
Can you provide some sample data?
Yes ! I attached it. Thank you.
So I would have in the same line for example that the feature "Quimper_B1" overlaps "Briec T3" at 31% . And also " Briec T3" overlaps "Quimper_B1" at 35% (maybe in an other line).
For now, I haven't both names in the same line. I only have "This overlap is 31% of Quimper_B1"
Thank you
Hello ! Sorry for late, I was in vacation. Thank you so much ! It exactly what I wanted. Thank you !
Have a good day!
