Re this question:
https://knowledge.safe.com/questions/33126/validateread-export-thousand-of-txt-to-csv-txt-are.html
I'm thinking it would be pretty useful if lines in a CSV (or text file) could be skipped depending on a particular test; for example it begins with a line with a comment character like
So, to that end I suggest adding the Tester transformer behaviour into the CSV parameters dialog, like this mockup:
