How do I set a parameter value to contain a list of files when running workspace using runner.runWithParameters
I am wanting to translate a list of files in a directory from one raster format to another by calling an FME workspace using the Python fmeobjects API.
import os
import sys
sys.path.append(r'C:\Program Files\FME\fmeobjects\python27')
import fmeobjects
workbench = r'D:\ESRIGrid2GeoTiff.fmw'
directory = r'D:\Test\A Folder'
raster_files = [os.path.join(directory, raster) for raster in os.listdir(directory)
                if raster.endswith('.asc')]
parameters = {'SourceDataset''\"' + '\" \"'.join(raster_files) + '\"',
              'DestinationFolder': directory,
              'InputCoordinateSystem''MGA94-54'}
fme_runner = fmeobjects.FMEWorkspaceRunner()
fme_runner.runWithParameters(workbench, parameters)
From the log file its seems the issue is that the FME reader splits the paths where there is a space in a folder/file name, even though each path should be enclosed in double quotation marks. I can run the workbench successfully from Python if I input a single file and through FME directly without any issues.
I am wanting to keep the script as flexible as possible so I'd prefer to avoid having users always ensure their directory paths do not contain any spaces.
Best answer by takashi
Hi @bparker, probably you will have to create the paths string like this.
"""""path1"" ""path2"" ""path3"""""
That is, the value of SourceDataset should be:
'"""""' + '"" ""'.join(raster_files) + '"""""'
Forum|alt.badge.img+19
  • October 18, 2017
  • October 18, 2017
Hi @takashi, thanks for the response, was still having the same issue with your suggested code but played around with the number of quotation marks and managed to get it working using:
'""""' + '""" """'.join(raster_files) + '""""'
