Exracting CW/CCW from arc
  • February 15, 2019
  • 41 views
todd_davis
Forum|alt.badge.img+21
Just recording this for anybody that needs it. FME Datainspector shows a CW/CCW (clockwise/counter-clockwise) direction for an arc under the geometry, but this value can't be extracted as a trait using a geometrypropertyextractor and the arcpropertyextractor doesn't list any attribute that return clockwise/counterclockwise.
Best answer by todd_davis
The answer is the CW/CCW in the datainspector is derived from the fme_sweep_angle. This attribute is returned as the sweep angle by the arcpropertyextractor. Positive values are counter-clockwise and negatives are clockwise
todd_davis
  • February 15, 2019
virtualcitymatt
Forum|alt.badge.img+34
@todd_davis - Thanks for sharing!
