Role Policies
  • September 12, 2017
  • 5 views
How do you set role policies in FME Server 2017? I don't see this link. How do I give a particular group access to certain features in FME Server 2017, such as the web user interface, notifications, repositories, etc?
courtney_m
Forum|alt.badge.img+5
In the FME Server 2017 Web User Interface, click on Security, then Roles. If you click on an existing role, or add a new one, you can select which permissions each role has.
Once you have defined the roles, you can click on the Users tab and assign each user to a specific role. It is also possible to change the permissions for each individual user, just by clicking on the user in the user tab, then changing the settings.
For more information on Users and specific permissions that can be set, see the FME Server Documentation here:
https://docs.safe.com/fme/html/FME_Server_Documentation/Content/WebUI/Users.htm
Thank you, that works. It was just a little too intuitive for me.
