Hello,
I have some questions about the AreaGapAndOverlapCleaner transformer.
In the documentation, it's written that the ''Tolerance is : The minimum distance between geometries in 2D before they are considered equal"
- How this distance is calculated between 2 polygones?
- If set to automatic, what does it mean that ''a tolerance will be estimated based on machine precision at the location of the input geometries."
Thank you.
