I have a point file containing instructions along routes, lets call this the major decision points. Each collection of points belong to a route and has a route id. This data is all contained within one file, which can be made of points belong to numerous routes.
I then have another file containing points for all junctions along the route, again this data has a route ID that is the same as the previous file for the given route. Lets call these the minor decision points and again this file is made up of points belonging to different route IDs.
The problem is that I need to remove the minor decision points when they are duplicates for major decision points, however, these should only be removed if they belong to the same route ID. To complicate maters some of these routes will overlap.
My initial idea was to create a loop transformer that processes features that belong to the same route ID, and then remove the duplicate minor decision points this way. However, I am stuck on exactly how I would achieve such a solution. Does anyone have any ideas or other potential solutions?
