Python Exception : DLL load failed: The specified module could not be found.
Hi ,
MIght have have already asked this question in the forum but no answer.
I have win 7 desktop with 2013 fme desktop.When I import cx_Oracle it gives the above mentioned error.
This seemed to be working in 2012 version of desktop earlier.
Note : Oracle client is 64 bit .
This problem is also a part of Fme server installation in similar environment .
Need help !!!
Best answer by david_r
which version of FME Desktop are you running, 32 or 64 bits?
A 64-bit Oracle client will only work with 64-bit FME.
David
  • June 24, 2013
David
  • June 24, 2013
Hi David,
In addition to Roy's problem, we are using fme Desktop
"2013 SP1 (20130325 - Build 13450 - Win64)"
  • June 24, 2013
Hi David,
I checked for the environemntal variables,binary client compatibility.
This seems to be the issue of the python cx_Oracle library shipped along with 64 bit of FME2013 and Server .
When I force upon to a custom python of mine the issue seems to be resolved.
Waiting a fix .
