I have a SQLite database (version 3, created in FME) that I want to use a Select statement with a regular expression in the SQLCreator transformer. According to the SQLite documentation the regexp() user function is a special one that need to be defined. Does anyone know a easy way to do this in FME? (it have to work in both PC and Mac environment)
