Configuring and Setting up GoogleGeminiConnector FME Hub transformer
  • March 7, 2025
  • 28 views
raghavendrans
Forum|alt.badge.img+9
I have been trying to setup the GoogleGeminiConnector in my FME Workbench to able to prompt and use the Gemini 2.0 Flash model to get me the results.
Since GoogleGeminiConnector is a FME Hub transformer, the documentation is not friendly for a first time user of Google Gemini.
The GoogleGeminiConnector makes use of the Google Gemini Web Service available on the FME Hub, which again needs some configuration.
There are several things to be configured from the Web Services in FME to Client ID/Secret, using the on the Google Console and other configurations, some within FME and some outside FME using the Google Console.
Due to the documentation is bits and pieces, a FME user is required to jump between various help documents and web pages.
It will be good if Safe can provide a single page workflow, that lists out the steps in the correct order to be followed to make the GoogleGeminiConnector to successfully work in FME Workbench.
Tx
SRG
evieatsafe
Forum|alt.badge.img+20
  • March 10, 2025
Hi ​@raghavendrans thanks for your post.
  • For your question about the web service, you should just have to create a project to get the client ID/secret which can be used in the web service.
  • The documentation in Hub transformers are not supposed to be walkthrough tutorials, although this is great feedback that we should create more resources on our knowledge base to make this process more user-friendly.
  • We are currently developing more resources, tutorials, and training material surrounding AI including Google Gemini 🎉 Keep your eye out for these resources in the next few months!
