Transposing data - Reverse of the transformer AttributeExploder
  • January 31, 2025
  • 56 views
hnahoulder
Hello Community,
I have data in the following format:
Attribute value
field1 a
field2 b
field3 c
field1 e
field2 f
field3 g
field1 j
field2 k
field3 l
Which transformer can I use to transpose my data into this format?
field1 field2 field3
a b c
e f g
j k l
The names field1, field2, and field3 can be dynamic, and their number may also vary
Forum|alt.badge.img+32
  • January 31, 2025
Do you have an attribute that defines what feature each row belongs to?
hnahoulder
  • January 31, 2025
The data follows a repeating pattern where every three (or N) rows correspond to one record. However, there is no explicit attribute that groups them. But  I can generate a column like objectid
Attribute value
objectid 1
field1 a
field2 b
field3 c
objectid 2
field1 e
field2 f
field3 g
objectid 3
field1 j
field2 k
field3 l
becchr
Forum|alt.badge.img+25
  • January 31, 2025
If you have an objectid to define the rows, and you know the fieldnames a flow like this should work:
I’ve attached a workspace based on your example, hope this helps
hnahoulder
  • January 31, 2025
Thank you, ​@becchr  for your help, but my problem is that I don’t know the field names because they are dynamic, so I can’t expose them
