I am attempting to add a Geocoder transformer to spatialize address data using a published geocoding service on ArcGIS Server. When running the address data to the transformer, it rejects every feature with “Code 403: Access to this resource is not allowed”. The REST URL and Portal credentials are all correct and I am able to get to the service in a browser, as well as access and use the Locator in ArcGIS Pro to geocode addresses. With that being said, I don’t know why access to the resource would be disabled in FME but nothing else. Any insight or suggestions would be appreciated, thank you!
Geocoder w/ ArcGIS Server - Error 403: Access to this resource is not allowed
Best answer by drewpurzycki
AliAtSafe wrote:
Thank you for posting and for your patience. Before delving further, could you share which version of FME Form/Desktop and ArcGIS Server your using? It’ll help us better assist your use case.
Thank you!
Hi Ali,
I’m using the ArcGIS Data Interoperability extension for Pro (2.9) and the ArcGIS Server is version 10.91.
Edit: I ended up needing to use an updated version of the Geocoder transformer, which let me use a Portal web connection to authenticate and connect to the locator REST service. Thanks!
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
