There a way to debug the execution of the script in FME?
gjaguilar
In a process in my company we use a Python script (PythonCaller) to call a download API, we need to modify it, but we get some errors that I don't get when running the script from Python on the Windows command line.
Is there a way to debug the execution of the script in FME?
Best answer by becchr
If possible, I try to avoid using Python and use baked-in FME functionality as much as possible
I don't know if it's an option here, but maybe you could consider an HTTPCaller to perform your downloadAPI calls?
joepk
Forum|alt.badge.img+20
  • April 3, 2024
I dont think there is an actual Python debugger available in FME. I usually use log messages at key points in my scripts to debug. You can log strings using logMessageString() https://docs.safe.com/fme/html/fmepython/api/fmeobjects/_log/fmeobjects.FMELogFile.logMessageString.html
gjaguilar
  • April 3, 2024
I`ll try
Thanks a lot
becchr
Forum|alt.badge.img+25
  • April 3, 2024
gjaguilar
  • April 8, 2024
I`ll try using HTTPCaller to perform my download API calls?
kolmodajn
Participant
  • Participant
  • September 4, 2024
With some fiddeling it is possible. After working on a project which grew very fast in complexity FMEs transformers could not handle it and the python code grew to much so i spent some time banging my head against the wall.
After some time i found this post about developing FME packages that mentioned debugpy, but the same principle applies to running pythoncallers.
https://docs.safe.com/fme/html/fpkg-sdk/hello-world-package/#__tabbed_1_2
TLDR ..
  • Install debugpy package into an existing python installation (Esri ArcGIS Python 3.9 for me, and i used PIP). This MAY cause instability with your existing python installation. We use an existing python installation because FME refused to accept a custom one, plus we make sure its compatible with FME Server.
  •  In the same folder as your FME-file, create a python file (.py). In that python module, paste the default python-code
  • Create another python module, debug.py and add the following code
  • # Debug -> Attach to process -> tcp://127.0.0.1:5678
    def start_debugging():
        import fme
        if fme.macroValues.get('FME_SERVER_HOST') == '':
            print('Running locally')
            import psutil
            targets = ['devenv.exe', 'code.exe'] # Visual Studio and VSCode
            processes = sorted([proc.name() for proc in psutil.process_iter(['name'])])
            if any(target in processes for target in targets):
                print('Visual Studio or VSCode running, enabling debugging')
                import debugpy
                socket = ("127.0.0.1", 5678)
                print('Starting debugging session...')
                print('Setting path')
                debugpy.configure(python=r'C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\python.exe')
                print('Trying to listen')
                debugpy.listen(socket)
                print(f'Listening ... waiting for debugger to connect to socket {socket}. \nIn Visual Studio -> Debugging -> Attach to process, connect to tcp://127.0.0.1:5678')
                debugpy.wait_for_client()
                print('Client connected')
                # debugpy.breakpoint()  # Optional: Set a breakpoint right after
            else:
                print('Visual studio or VSCode not running, no debugging enabled')
        else:
            print('Running on server, no debugging')
    # Use this method to find the python path to use in the debugpy.configure line
    def print_python_paths():
        import sys
        print(f'System version  {sys.version_info}')
        for path in sys.path:
            print(f'System path  {path}')
  • Create a PythonCaller add the following code”. Make sure that the “Class to Process Features has the same name as the class you are importing.
  • In Visual Studio (VS Code works as well) create a new Python project. Under Python Environments add the arcgispro-py3 one and set it to active. It will now fild all installed packages.
  • To not get errors from fme and fmeobjects, copy the .py and .pyd files from the python installation you are using into the same folder that your fme-file and python modules are
    • fme.py
    • fmebootstrap.py
    • fmeobjects.cp39-win_amd64.pyd
  • When you start your script you should see this text
  • So go ahead and connect your debugger and enjoy breakpoints, code completion, copilot, linting and everything else that comes with a good IDE 🔥
