Adding a new label for las file based on clipping of points
  • May 8, 2023
  • 5 replies
  • 93 views
I am trying to add an extra label for each point of the point cloud based on whether or not they were located inside or outside the gml building model.
When I clipped a model with my point cloud data with "Clipper", it only identified that point cloud was outside and that point cloud data was identified as 1 feature own on its.
How do I label/mark each point in the point cloud whether they clipped with the model or not and then save it as an extra information/variable in a new las file.
Best answer by khairilariffin
To update. I was able to split data into its individual parts for clipper comparison using PointCloudToPointCoercer as adviced.
I then turn each of group of points into individual PointCloud feature. From here used PointCloudComponentAdder to add label based on which group, Inside or Outside.
I then combine both group back together before writing/saving them.
Remember to set the Inside or Outside under Additional component when setting up the LAS writer. Attached my workspace for reference.
daveatsafe
Forum|alt.badge.img+20
  • May 9, 2023
Hi @khairilariffin​,
You can use a pair of PointCloudComponentAdders after the Clipper, one connected to the Inside port, and the other connected to the Outside. Set a comment component name in each transformer, one set to the inside value, and other set to the outside value. Finally, send the outputs of both PointCloudComponentAdders to a PointCloudCombiner to merge back into a single cloud again.
Screen Shot 2023-05-09 at 1.32.20 PM
Hi @daveatsafe, thanks for the reply.
FME reads my LAS file as one feature. As such when I used Clipper, it read entire Point cloud as one feature instead of individual points and when compared to the GML model is read as Outside only. I am trying to identify and label each point in the point cloud if they are either inside or outside when compared to the GML 3D Model.
daveatsafe
  • May 10, 2023
It looks like the GML features you are using as Clippers are being rejected. To clip a point cloud, the Clipper features should be either polygons (for 2D clip), or solids for (3D clip). 3D features from GML are usually a collection of surfaces rather than a solid, so you may need to use a SolidBuilder transformer to convert these to proper solids. A successful solid will require that there be no gaps in the input surfaces.
The 3D GML model is not causing the issue, rather I am still not able to label the individual point cloud from my LAS file. I was able to find a Transformer called PointCloudFilter but it requires an expression input which I do not know what to fill in since I require all the points from the point cloud.
