gentrans error with generated command line
I am trying to transform a the KML within a KMZ file to MapInfo format using gentrans. The following works in the CMD:
"C:\\Program Files\\MapInfo\\Professional\\UT\\fme.exe" GENTRANS OGCKML "D:\\Workplace\\Projects\\Acciona\\MI_read_KMZ\\testing\\UT\\PARQUE1.kmz" MAPINFO "D:\\Workplace\\Projects\\Acciona\\MI_read_KMZ\\testing\\UT\\tab"
I have used FME GENTRANS GUI GENERATE_CMDLINE to generate a command line. If I run the result on the command line with: fme.exe gentrans <generated commandline> it fails.
The command line I use is the following:
"C:\\Program Files\\MapInfo\\Professional\\UT\\fme.exe" GENTRANS OGCKML "D:\\Workplace\\Projects\\Acciona\\MI_read_KMZ\\testing\\UT\\PARQUE1.kmz" "RUNTIME_MACROS,\\"KML21_LOG_VERBOSE,No,KML21_RASTER_READ_MODE,GroundOverlay,KML21_SCAN_SCHEMA,Yes,KML21_FAIL_ON_NETWORK_ERROR,No,KML21_DELETE_DOWNLOADED_FILES,Yes,KML21_TRAVERSE_NETWORKLINKS,All,KML21_MOVE_TO_KML_WORLD_COORDSYS,Yes,KML21_APPLY_MODEL_TRANSFORMS,No,KML21_MAX_NETWORKLINK_TRAVERSAL_DEPTH,5,KML21_DATASET_ENCODING,,EXPOSE_ATTRS_GROUP,FME_DISCLOSURE_OPEN,OGCKML_EXPOSE_FORMAT_ATTRS,\\""kml_id,kml_buffer kml_lookat_latitude,kml_real64 kml_lookat_longitude,kml_real64\\"",USE_SEARCH_ENVELOPE,NO,SEARCH_ENVELOPE_MINX,0,SEARCH_ENVELOPE_MINY,0,SEARCH_ENVELOPE_MAXX,0,SEARCH_ENVELOPE_MAXY,0,SEARCH_ENVELOPE_COORDINATE_SYSTEM,,CLIP_TO_ENVELOPE,NO,NETWORK_AUTHENTICATION,,_MERGE_SCHEMAS,YES\\",META_MACROS,\\"SourceKML21_LOG_VERBOSE,No,SourceKML21_RASTER_READ_MODE,GroundOverlay,SourceKML21_SCAN_SCHEMA,Yes,SourceKML21_FAIL_ON_NETWORK_ERROR,No,SourceKML21_DELETE_DOWNLOADED_FILES,Yes,SourceKML21_TRAVERSE_NETWORKLINKS,All,SourceKML21_MOVE_TO_KML_WORLD_COORDSYS,Yes,SourceKML21_APPLY_MODEL_TRANSFORMS,No,SourceKML21_MAX_NETWORKLINK_TRAVERSAL_DEPTH,5,SourceKML21_DATASET_ENCODING,,SourceEXPOSE_ATTRS_GROUP,FME_DISCLOSURE_OPEN,SourceOGCKML_EXPOSE_FORMAT_ATTRS,\\""kml_id,kml_buffer kml_lookat_latitude,kml_real64 kml_lookat_longitude,kml_real64\\"",SourceUSE_SEARCH_ENVELOPE,NO,SourceSEARCH_ENVELOPE_MINX,0,SourceSEARCH_ENVELOPE_MINY,0,SourceSEARCH_ENVELOPE_MAXX,0,SourceSEARCH_ENVELOPE_MAXY,0,SourceSEARCH_ENVELOPE_COORDINATE_SYSTEM,,SourceCLIP_TO_ENVELOPE,NO,SourceNETWORK_AUTHENTICATION,\\",METAFILE,OGCKML,COORDSYS,,IDLIST," MAPINFO "D:\\Workplace\\Projects\\Acciona\\MI_read_KMZ\\testing\\UT\\tab" "RUNTIME_MACROS,\\"VERSION,900,WRITE_REGION_CENTROIDS,no,TWO_POINT_LINE_AS_POLYLINE,no,STROKE_ARCS,no,MAP_LARGEINT_TO_DECIMAL,yes,_USE_SOURCE_BOUNDING_BOX,no,PLUGIN_MAX_CHANNELS,100,COORDSYS_STATEMENT,,MIF_MINX,,MIF_MINY,,MIF_MAXX,,MIF_MAXY,,DESTINATION_DATASETTYPE_VALIDATION,Yes,COORDINATE_SYSTEM_GRANULARITY,FEATURE_TYPE\\",META_MACROS,\\"DestVERSION,900,DestWRITE_REGION_CENTROIDS,no,DestTWO_POINT_LINE_AS_POLYLINE,no,DestSTROKE_ARCS,no,DestMAP_LARGEINT_TO_DECIMAL,yes,Dest_USE_SOURCE_BOUNDING_BOX,no,DestPLUGIN_MAX_CHANNELS,100,DestCOORDSYS_STATEMENT,,DestMIF_MINX,,DestMIF_MINY,,DestMIF_MAXX,,DestMIF_MAXY,,DestDESTINATION_DATASETTYPE_VALIDATION,Yes,DestCOORDINATE_SYSTEM_GRANULARITY,FEATURE_TYPE\\",METAFILE,MAPINFO,COORDSYS,"
daveatsafe
Forum|alt.badge.img+19
Hi @michielz​,
Thank you for alerting us to this problem. I have escalated this issue to a Support Case, and will follow up through Support.
Very good, Support has answered and solved the error. The problem is that, using FME GENTRANS GUI GENERATE_CMDLINE and marking specific attributes from the KML file (OGCKML_EXPOSE_FORMAT_ATTRS), there is an error in generating the escape characters and the quotes. \\"" instead of \\"\\" in the list of attributes to get from the KML file. A simple replace of "" with "\\" in the generated command solves the problem.
