Failed to write point cloud into existing Oracle Point Cloud Table
  • February 6, 2023
  • 5 views
Hell FME Community,
i am trying to write the data into existing Oracle Spatial Point Cloud table. However, the translation fails with the following error: "ORACLE Writer: writing the point cloud failed because it has 3 extent dimensions, but the table 'AHN_BLCK' column 'BLK_EXTENT' contains data with 0 extent dimensions. The number of dimensions must match for all point clouds in a table."
The "BLK_EXTENT" column has the SDO_GEOMETRY data type.
Does anyone have any ideas?
Best regards
  • February 15, 2023
@pryshlak23​ Do the steps outline here help?
