Excel Fanout with multiple static rows/headers
pkno
Forum|alt.badge.img+5
Hi everyone,
I am trying to split a large table into multiple files and was playing around with the dataset fanout feature. My table has multiple header rows that contain explanations of each attribute that I wish to keep in each file created by the fanout but I cant seem to make it work.
An alternative that I can also see working is to add a static Sheet to each fanout-file which then contains these explanations. I wasnt able to make that work either though.
Any help would be much appreciated.
Be the first to reply!
