StringReplacer to replace all text?
I am wanting my StringReplacer to search for values which start with a certain string, and replace the ENTIRE value with a new string (not just the start).
I have table with a list of values starting with "Sh 1" and "Sh 77", and they all have following text after Sh 1 and Sh 77. I would like to replace the entire value, e.g. "Sh 1 Rs 401 Rakaia to Chertsey" should be replaced with "State Highway 1".
I have tried a few expressions, but currently I am only able to replace the "Sh 1" part of the string, not the following text.
How do I change my expression so the entire value is replaced?
geomancer
Forum|alt.badge.img+47
  • May 31, 2023
You are close, use one of these to match the whole text starting with "Sh 1 ":
^Sh 1 .+
^Sh 1 .*
" .+" means one or more characters, ".*" means zero or more characters.
geomancer
  • May 31, 2023
Creating regular expressions is fun, but it is probably much easier to use Conditional Values in an AttributeManager.
Conditional_Value_2
Forum|alt.badge.img+32
  • May 31, 2023
If you want to replace Sh 1 with State Highway 1 and Sh 77 with State Highway 77, you could do this
(Sh\s)(\d+).*
So match Sh followed by a space and replace with State Highway, match the numbers after and put that group (\2) back in the replacement text
