Splitting one column into many
How would I go about spitting a column every 12th row so I have three features from column a instead of oneimage
danilo_fme
Forum|alt.badge.img+42
  • March 4, 2022
Hi @qitkyle​
You can use the custom transformer Grouper for split number of rows that you want.
Thanks in Advance,
Danilo
  • March 7, 2022
danilo_fme wrote:
Hi @qitkyle​
Thanks in Advance,
Danilo
Thanks. How would I then go about splitting the single column to multiple columns by using the row grouper row attribute?
connecter
  • March 7, 2022
Hi @qitkyle​,
maybe this help you:
Workflow GrouperThe result is:
Result
