Transposing rows to columns
  • December 15, 2022
  • 1076 views
superjets
This would be simple to do in Excel, but I can't figure it out on FME. The problem is I need to transpose or pivot rows to colums, as in example (I have formatted and calculated the totals to first box):
imageI have tried with AttributePivoter and AttributeCreator/Aggregator, but it doesn't work. Any help would be appreciated, I've tried to google, but with no luck. I have also tried to pivot the unprocessed data and calculate it there.
Best answer by tomfriedl
tableParams FeatureMerger:
Group by name
Merge incoming attributes
tomfriedl
Forum|alt.badge.img+13
  • December 15, 2022
Group by name
superjets
  • December 15, 2022
Yeah, thanks a ton! With help of AttributeExposer it worked.
That was super-fast!
