How to find all routes ?
spiderman
Forum|alt.badge.img+7
Hello ,
i have many lines and many points .
i have used anchored snapper then topology builder then edge output as in input network for shortest pathfinder
and I used every point connector transformer for points to get lines to use it as input for from to shortest path finder .
my question : i need to find all routes that possible .
shortest path finder has found many paths
but there are still too many no paths .
How could I find all routes between points ?then extract ids from each route .
i hope there is a good idea let me know .
i have spent much time but no success .
fme 2021
Forum|alt.badge.img+49
The ShortestPathFinder will find, as the name implies, the shortest path. It doesn't find other paths.
Perhaps the NetworkTopologyCalculator does what you want?
spiderman
  • August 16, 2023
network topology did not help me in my case .
i have read in previous posts ,that there is inline querie can use to find all routes but I did not get the idea ? Do u have sample workspace about using inline quierie to find all possible routes ?
or will be possible to use more than one shortest pathfinder to find the rest of paths ?
anf how should I know that the transformer has found all possible routes ?
