i used feature reader to read WMS (Web Map Service) , to read cartographic map .i would like to cancel specific color from cartographic map ,to able not showing some lines .Does it possible ?
  • October 8, 2021
  • 7 views
spiderman
Forum|alt.badge.img+7
i used feature reader to read WMS (Web Map Service) , to read cartographic map .i would like to access thedifferent colors in cartographic map and use tester transformer ,to let the lines that include this specific color not showing .
i would like to cancel the pink color from cartographic map .
How could i achieve that ?
Thanks in advance
FME 2018
  • October 8, 2021
A WMS returns a rendered image (raster), and it's not usually possible to remove individual features based on pixel values alone.
A couple of alternatives:
  • Talk to the publisher of the WMS and request a custom layer that corresponds to your requirements
  • Use a WFS with the same data, if available, then you'll get the vector features with attributes and can filter and style them yourself, e.g. using the MapnikRasterizer.
