I am using StringReplacer to remove unwanted words from an excel column. Is it possible to remove more than one word at a time or do you have to add a StringReplacer for every word I need to remove.? Thank you
  • February 1, 2021
  • 6 replies
  • 98 views
I
Best answer by ebygomm
I wish to remove certain words from a postal address completely.
Using the StringReplacer I tried using the text editor  like you mentioned in the 'Text To Replace' option to build a SQL style query
In ArcMap this would be
[Address] = "Value1" or [Address] = "Value2" to select the words to remove
in FME text editor I tried the following (and may well have this completely wrong)
@Value(Address) = "Value1" or @Value="Value2"
But it doesn't seem to be finding the values
I am leaving  the Replacement Text box blank
Thanks
Mark
If you use mode regular expression, you can build a regular expression to match multiple words and replace with nothing, e.g. to replace dog or cat you could use
\bcat\b|\bdog\b
the \b before and after the words indicates a word boundary, this means that you only match instances of cat and dog not catchment or dogwood. The | means or
Forum|alt.badge.img+46
  • February 1, 2021
Are you wanting to replace multiple words with one single word? In which case you can use regex matching to specify multiple words.
Or if you have multiple words you want to replace, each replaced with a different value you can look at the StringPairReplacer
  • February 1, 2021
Thanks
Mark
Forum|alt.badge.img+62
Thanks
Mark
Try using a Regular Expression: [Value1|Value2] should work. Make sure to set the mode to "Replace Regular Expression" though.
  • February 1, 2021
Thanks
Mark
\bcat\b|\bdog\b
  • February 1, 2021
Hello,
Thank you @ebygomm and @redgeographics for your help - that's worked perfectly
I am new to the forums - can I mark this post as answered?
Mark
  • February 1, 2021
Hello,
Mark
There should be options at the bottom of each post
Upvote * Reply *Select as Best
Select as Best will mark the question as answered
