Decode JSON-response to Excel
mathiku
Forum|alt.badge.img+7
I have a lot of JSON-responses that wraps an base64-encoded excelfile (response.json).
If I extract the data-part and try to decode it using BinaryDecoder (base64 to hex I guess). And then decode to ASCII, I get only a few chars that makes no sense.
If I use an online-service (https://www.base64decode.org/) and add the data-part of the JSON-file (JSON response -.....) I get a perfect excel-file.
I can't seem to figure out the part that the online-service performs and the part I can't make FME do.
Any help is appreciated.
Best answer by nielsgerrits
I can get it to write a readable excel file using the following steps:
  • Use a BinaryDecoder to go from Base64 to Binary (fme-binary).
  • Use an AttributeFileWriter to write to a file, Target File Encoding = Binary (fme-binary).
Sample attached.
nielsgerrits
Forum|alt.badge.img+53
  • March 2, 2022
Sample attached.
mathiku
  • March 9, 2022
Sample attached.
Thank you. It works like a charm!
