How can I expose the raster feature information? Looking to expose the band values.
nielsgerrits
Forum|alt.badge.img+52
You want to know a cell value of a specific point? PointOnRasterValueExtractor
You want to create vectors from all rastercells? RasterCellCoercer
  • April 6, 2021
I would like to know it for all cells. Looking to take a large number of raster images from an ESRI SDE and convert them to a geo-tiff however they are coming out black
nielsgerrits
I'm by no means a Rasterdata expert, but I think this has to do with the alpha band (transparency) being written to the GeoTIFF. Your solution depends on what you have and what you need, but if I guess correctly you can use the RasterBandSeparator and the tester to remove the alpha band and only write the databand (BAND0 in you screenshot) to the GeoTIFF.
  • April 6, 2021
Have you looked at the RasterPropertyExtractor and the RasterBandPropertyExtractor?
