What is the best tolerance value for anchored snapper segment type
soly
Forum|alt.badge.img+3
Hello ,
i would like to know ,what is the best tolerance value that use in anchored snapper (segment type ) to avoid any problems
i have used 0.02 , automatic .
it works well for some lines but it make problems for some lines when they are so close or cross eachother .The segment type of anchored snapper make lines to be intersected instead of cross lines .
which value that people has experience with segment type always use without any problems ?
is there any alternative for anchored snapper segment type that do the same purpose
fme 2021
DanAtSafe
Forum|alt.badge.img+18
  • October 7, 2023
Hi @soly​ Ideally the Automatic Tolerance would be right for every situation in your dataset, but there will be exceptions. At least the tolerance is logged so you have an idea of how to adjust it manually. Are you sure that you need to adjust the Tolerance and not the Snapping Distance? You might need two or more AnchoredSnappers - start with lower values and then increase for those features that come out of the Untouched port.
soly
  • October 7, 2023
for Snapping distance ,what is the lower value that should I start ?
hkingsbury
Forum|alt.badge.img+51
  • October 8, 2023
That depends on your use case and the quality of the data. Do you want features 1000m away to snap? or do you only want feature 1m away to snap?
soly
  • October 12, 2023
I have used snapping segment 0.02,May be it is good for some lines but for specific lines ,I found that it moved specific line to close intersections of some lines .
but I need to execute to snap 0.02 for lines but because it moved line to wrong location .and May be some other lines have problem also but I did
see it .
so I am not sure what should I do ?
hkingsbury
  • October 12, 2023
Try the anchoredsnapper, this give you an option to specify 'anchors' which don't move and 'candidates' which will snap to anchors within the snapping distance
