JSONTemplater and XQuery with nested for and if statements
  • November 18, 2020
  • 52 views
dms2
Forum|alt.badge.img+11
I managed to generate a new json from the original one getting the info I need but now I see there's some missing data.
Each project group has an id, lat-lon info and an array with data for every project inside the group.
I generate a new json with a feature for every project but need to also add a feature for every project group without projects in it.
This is what I have:
    let $doc := fme:get-json-attribute("_response_body")
    for $i in (1 to jn:size($doc))
        let $id := $doc($i)("id")
        let $lat := $doc($i)("lat")
        let $lon := $doc($i)("lng")
        let $proj := $doc($i)("projects")
        for $j in (1 to jn:size($proj))
            return
                {"id" : $id},
                {"lat" : $lat},
                {"lon" : $lon},
                {"proj_name" : $proj($j)("name")}
I've tried to nest an If statement to check when $proj is empty but it throws an error.
Forum|alt.badge.img+32
  • November 18, 2020
What have you tried with the if statement? Can you share an example of the json in the _response_body?
dms2
  • November 18, 2020
Ok, got it!
No nesting needed. XQuery always puzzles me and it is because I always try to recreate exactly what I'd do with some other language.
So this works :
        let $size := jn:size($proj)
        let $n := if ($size = 0then 0 else 1
        for $j in ($n to $size)
            return
                {"id" : $id},
                {"lat" : $lat},
                {"lon" : $lon},
I've changed this:
 To this:
