How to detect lines that intersect without nodes/junctions between one or the two of them?
  • June 1, 2022
  • 32 views
arthy
Forum|alt.badge.img+8
Let's say I have two Line L1 and L2 that intersect on point A.
Line A has node on point A but Line B does not.
DanAtSafe
Forum|alt.badge.img+17
  • June 2, 2022
Hi @arthy​ I don't understand your scenario exactly, but I think you would need to check for intersection between the lines with a SpatialFilter or SpatialRelator, then extract the endpoints (nodes) with a Snipper - or get all vertices using a Chopper, and then compare those points with the other line using a 2nd SpatialFilter.
