Hello - I have a file geodatabase where most feature classes contains an attribute 'text_desc'. I would like to extract all unique values, and concatenate those into a single comma-separated attribute to generate a report. Due to slow gdb read times in FME, I would like to do this in PythonCaller for efficiency.
Is this possible?
