json output remove top levels
oliver.morris
Forum|alt.badge.img+12
Hi, I have created some JSON in FME but would like to remove the first couple of levels.
At the moment I have:
        "output" : {
            "status" : "200",
            "body" : [
                    "well_id" : 25325,
                    "well_name" : "MYALL_CREEK_3",
                    "latitude" : -27.046011,
                    "longitude" : 149.236806
                {etc
ideally I would like to remove the "output" level
            "status" : "200",
            "body" : [
                    "well_id" : 25325,
Could you please tell me how to achieve this.
For reference my workbench looks like:
Many Thanks,
Oliver
Best answer by david_r
Since you're already using the JSONTemplater, I would suggest that you simply use the TEXTFILE writer rather than the JSON writer. Simply change the JSONFormatter output attribute to "text_file_data" and you should be ready to go.
That should accomplish what you're asking.
  • March 23, 2018
oliver.morris
  • March 23, 2018
perfect, yes that did the job
