Desired functionality scenario: criteria stating the minimal Requestor overlap percentage the Supplier needs to have. (e.g., Supplier overlaps at least 80% of Requestor, or else the record is <Rejected>).
I believe that adding this property to the SpatialRelator would add a lot of value and save a lot of complexity and time.
But for now, I would like to know in as much of a step-by-step fashion as possible, how to achieve this functionality, which I believe could be accomplished more elegantly with a SpatialRelator upgrade.
Feel free to chime in if you also support this functionality.
