Hi, I am trying to reduce texture resolution on a .obj model. This is what i have currently:
The output at AppearanceSetter does not have any textures applied to it. I have tried connected AppearanceStyler to AppearanceSetter directly and it also does not work. So I am assuming that perhaps the way that I am setting the appearance is wrong. Images attached below shows before and after
I have attached the .fme workspace.
The .obj can be found here: (due to size limit here)
https://drive.google.com/file/d/1Cg6wNNzllzl0M7O6ifciswnPfC_0z57s/view?usp=sharing
