filter polygons that contain no further polygons
I want to filter from a dataset the polygons that contain no further polygons. I have tried the Transformer AreaOnAreaOverlayer and SpatialRelator (Attributes (s) that Must Differ = element_id) so far.
Best answer by takashi
I think the SpatialRelator (Spatial Predicates to Test: Requestor Contains Suppliers, Attribute(s) that Must Differ: element_id) might help you. The output feature having 0 in the _related_candidates attribute would be your required result.
Forum|alt.badge.img+19
  • February 4, 2019
Thank you takashi. Your tip helped a lot.
