Find the cluster with most poinst and calculate median lat/long of these points
Hi all,
I got some points like in the pic. How can I create a cluster with most point and get the long/lat of the center?
Thank you all
gio
Forum|alt.badge.img+15
  • May 4, 2018
@s3585629
You could try
NeighborhoodAggregator.
erik_jan
Forum|alt.badge.img+17
  • May 4, 2018
As @gio mentions you start with the NeighborhoodAggregator, followed by the PartCounter to get the number of points per "clump" (alias for NeighborhoodAggregator is Clumper. Using that in FME will work too). You can follow this by a CenterPointReplacer to find the center point of the "clump".
