Using a Python startup script to delete a row in an Excel spreadsheet
  • April 23, 2013
  • 9 replies
  • 380 views
I need to delete the first row of an Excel spreadsheet before reading and importing it in FME (column headers are in the second row).
I found this script to use at startup (from http://stackoverflow.com/questions/12311345/manipulating-excel-2007-files-using-python):
#First we need to access the module that lets us connect to Excel
import win32com.client
# Next we want to create a variable that represents Excel
app = win32com.client.Dispatch("Excel.Application")
# Lastly we will assume that the workbook is active and get the first sheet
wbk = app.ActiveWorkbook
sheet = wbk.Sheets(1)
# delete the first row in your active sheet
sheet.Rows(1).Delete()
I tried it, but I get an error message saying I don’t have the win32com module on my computer. (I do not want people to have to download anything to use my workspace.)
Reading further, I found that maybe I should use someting like that instead :
import os
app = FME_MacroValues['SourceDataset_XLS_ADO']
Something is still missing as I now get this message :
Python Exception <AttributeError>: 'str' object has no attribute 'ActiveWorkbook'
If you can provide any help ...
I am new both to FME and Python.
  • April 23, 2013
Hi Cath,
if you just want to ignore the first n number of lines in your translation, it would be a lot easier to insert a Counter after the reader, followed by a tester with something like "_count > 2" as the test clause. You then only connect the PASSED port to the rest of your workflow, effectively dropping all other features.
David
  • April 23, 2013
Hi Cath,
'FME_MacroValues['SourceDataset_XLS_ADO']' returns a character string of the Excel file path, you can't control Excel object unless using the win32com module.   I think using a combination of Counter and Tester would be a general solution in such a case, I also often use it. I would provide another option, that is to set 'Start Feature' parameter of the reader to N (0-based row number to start reading) on the Navigator window of your Workbench.
Takashi
  • April 23, 2013
Thanks  David and  Takashi.
I should add some extra information:
I need to use the second row of my Excel spreadsheet as column headers. Thus, when I use a counter and tester, or StartFeature parameter, my file has already been imported with either first row as headers or no headers specified (column automatically designated as F1, F2, F3, ...). I have also tried using the bulkrenamer, but unsuccessfully.
Thanks in advance for any comment !
Catherine
  • April 23, 2013
Hi Catherine,
here is a way to accomplish this (tested with FME2013sp1):
  • Make a copy of your Excel input file without any header row(s)
  • Open FME and create your reader input type. This will create an input feature type with the correct field name definitions.
  • Set the Start Feature value (=2 if you have one header line), as per Takashi's suggestion
  • Point your reader to the Excel file with the header
This should hopefully give the desired result.
David
  • April 23, 2013
Hi Catherine,
I'm not sure whether there is a way to read the second row of worksheet as attribute names. If number of columns is not so many, AttributeRenamer would be a simple solution. If not, SchemaMapper and AttributeExposer would be a more flexible way. Have a look at those transformers.
Takashi
  • April 23, 2013
I have tried both of your solutions.
David, I tried your suggestion, but although I do get the header columns I want, the data is not imported (looking at the table in the Data Inspector. Am I doing something wrong?
Takashi, Unfortunately I have a very large number of columns (Itried the bulkRenamer) and I cannot be assured that the column names will always be exactly the same.
Thanks again,
Catherine
  • April 23, 2013
Hi Catherine,
I tested my last suggestion on my pc using FME2013sp1 and the data was read correctly. Try sending the result to a logger rather than to the Data Inspector to see if that makes a difference.
David
  • April 24, 2013
Hi David,
I use the same FME version on pc, and still, I do not get any data. I have tried the logger and 2 output files. The logger shows that values are attributed, but still, the result is empty.
Any other suggestion?
  • August 14, 2014
I am having a similar issue. I have two styles of Excel files; Ones that start with a header row and then data and ones that have 7 lines of general information, row 8 are my headers and row 9 starts my data.
This is coming in as an email attachment, and all the headers are ordered differently and have different names. I am trying to normalize each of them and put the data into a SQL Non-spatial DB.
I can't use the Start Feature parm because that is too general. I have tried the Py script above and as well, I am getting the same error message (not sure what to put for a universal workbook name since they are all named differently). When I read in the data FME reads that the headers start on row 8, but I they are attribute values instead of headers.
 I get this warning message XLSX Reader: Feature type 'WorkOrderDetail' of dataset 'J:\\READ\\RTASQ\\EDW 7.26.14 (1).xlsx' has attribute 'Record Changed' that does not match a header column in the file. This attribute will not be produced.
SO.....how can I make row 8 my header column?
