I am using the Text File writer, and wish to fanout output to files in different folders (where the file name in each folder is cosistent).
I have been able to do the opersite (i.e. fanout to uniquley named files in a single folder) using the Advanced>Fanout Datset settings.
Short of running from the command line, with a specified output folder parameter, is there any way I can dynamicaly direct Text File outputs to different folders?
