How to get the geometry property “Min Extents” and “Max Extents” to create a new geometry polygon coordinate?
How to get the geometry property “Min Extents” and “Max Extents” like in FME Data Inspector in my FME Workbench so I can create a new geometry polygon coordinate?
ciarab
Forum|alt.badge.img+9
  • October 4, 2017
Try using the boundsextractor
erik_jan
Forum|alt.badge.img+17
  • October 4, 2017
Or if you need the polygon, use the BoundingBoxReplacer.
That will replace the geometry by a box, using the min and max extents.
Thanks for both replies.
