Encountered 3D Geometry missing appearance information. Geometry will be written without textures
  • August 5, 2018
  • 24 views
Hi. I got this problem while converting my IFC model to gdb (geodatabase folder). My model is quite complex which consist of the Architecture model. When I try to convert it to gdb, there are only some features that are successfully convert. Others features with "Encountered 3D Geometry missing appearance information. Geometry will be written without textures" warning is not converted to gdb. I actually need that texture to be in my geodatabase model. Can anyone help and guide me to solve this problem? Im a new user of FME.
xiaomengatsafe
Forum|alt.badge.img+3
Hi @aina04426, Seeing that you haven't got any suggestions yet on this issue. I'm wondering if it might be helpful to attach a sample of your IFC data and the workspace, and maybe the log too, so the community can have a better understanding of the scenario and may be able to provide some help?
