Export coded domain from Geodatabase
  • January 24, 2014
  • 33 views
philippeb
Forum|alt.badge.img+17
I am using FME2014 and I am using this documentation : http://fmepedia.safe.com/articles/How_To/Working-with-Geodatabase-Subtypes-and-Domains
At the step 3 of reading domain values in the documentation, I click on VIEW of the coded_domain (DIAMETER) and I have my list of coded domain values from my GDB. Exemple :  http://fmepedia.safe.com/servlet/rtaImage?eid=ka1a0000000cwS9&feoid=00N30000007dMlC&refid=0EM30000000TpzI
What I want to do is to export this list into something else like Excel.
I have hundreds of coded domain values into my GDB, each of them connected to Feature Class.
I would like to export the coded domain values (code and description for each of them) from all the FC I would choose to read into FME.
You think it is possible?
Thank you!
Best answer by timst_rk
I think it's possible, but it will need a lot of work.
Perhaps exporting the geodatabase to xml, reading the xml and outputting all FC's with domains and the domains beside them is easier?
I found a tool using google to do just that, but I have lost it - sorry - it may still be out there...
/Tim
  • January 29, 2014
/Tim
