Polygon Vertex
May I know that how to export each vertex from a geometry?
I tried to use Vertex Creator before, but the output is not one record for one point, but one record for all points.
For example, there is a polygon with 4 vertex,
The result I want to get like this:
Pointxy1xxxxxxxxxxxx2xxxxxxxxxxxx3xxxxxxxxxxxx4xxxxxxxxxxxx
but not like this:
Polygonx1y1x2y2x3y3x4y41xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Is there any function can help me solve this case?
Thank you.
Forum|alt.badge.img+35
  • April 25, 2017
Coordinate extractor extracting all coordinates followed by a list exploder. Note that vertex numbers start from 0 not 1
erik_jan
Forum|alt.badge.img+18
  • April 25, 2017
I would use the CoordinateConcatenator first (to create a concatenated list, using comma as ordinate and semi-colon as vertex seperator).
Then use the AttributeSplitter to create a list (splitting on semi-colon).
The ListExploder will give you a feature per list item (these will be the points).
The second AttributeSplitter (split on comma) will give you the X and Y coordinates as attributes.
That is a lot of typing.
An easier way:
Use the Chopper to create vertices.
Use the CoordinateExtractor to extract X and Y to attributes.
Should have thought of this one first.
gio
Forum|alt.badge.img+15
  • April 25, 2017
or simply Chopper by Maximum vertices =1.
verdoodtdries
Another method is to use the FME Objects Python API: https://docs.safe.com/fme/html/FME_Objects_Python_API/index.html. I would recommend to use this option if you're familiar with Python.
Within the class FMEPolygon you can use the inherited function bounds() which returns a tuple of FMEPoint objects. Next you can loop over this tuple and return each point. Finally remove duplicate points if necessary.
  • May 2, 2017
Thank you, may I know any setting on it?
  • May 2, 2017
An easier way:
Thank you, may I know any setting?
As I can proceed CoordinateConcatenator and get the result of
BuildingIDCoordinate 1xxxxxx , xxxxxx , xxxxxx ; xxxxxx , xxxxxx , xxxxxx ;........
  • May 2, 2017
Thank you, will try this method later.
  • May 2, 2017
Thank you for your help.
itay
Forum|alt.badge.img+17
  • May 2, 2017
Setting it to 1 on the Maximum Vertices will result in point features, setting it to two will reslut in lines with maximal 2 vertices etc, etc see the help for more detailed information about the transformer.
  • May 2, 2017
What exactly do you need? Your OBJECTID will be the equivalent of a polygon id, whereas the "chopped" attribute will contain the vertex number in each polygon.
If you need the X/Y values you can use the CoordinateExtractor after the Chopper, as mentioned below.
olyster
  • June 29, 2018
Maybe I'm missing something but chopped attribute will contain yes or no... not the vertex number.
  • June 30, 2018
You are right, the Chopped Indicator Attribute just indicates if the output feature was chopped (yes) or not (no).
If you need to add index attribute to the output features, consider using a Counter additionally. Or, the VertexExtractor (from Hub) might help you.
