Calling workbenches with large data in FME Server 2013
   I have two workbenches in FMEServer 2013. First workbench needs to call second workbench by passing a string of 2000-3000 characters and second workbench will receive it as a publish parameter.
I tried with job submitter but it works with only small size values. Please suggest me any solution.
Subrat.
  • July 5, 2013
you could consider writing the string data to a suitable format (such as text or FFS) before passing the filename to the second workspace.
David
  • July 5, 2013
Hi David,
     Would you please give an example in brief?
Thanks.
  • July 5, 2013
First workbench
 - Do your processing
 - At the end, write stringdata to filename.ffs
 - WorkspaceRunner, pass "filename.ffs" as parameter
Second workbench
 - FFS reader on published parameter, reading "filename.ffs" and using the stringdata read from the file for the processing
David
  • July 5, 2013
In Fme desktop, i am able to call workbench with workspace runner by specifying fmw location. But in server how to specify a published workbench???
  • July 8, 2013
Have a look at the FMEServerJobSubmitter.
David
