How to deal with epsg:314685783
  • June 28, 2018
  • 29 views
dollargis
My organisation keeps its data in epsg:314685783, which is an extension of the GK4-epsg:31468 with the epsg:5783 altitude reference system ( https://epsg.io/5783 )
How can I read such data from an oracle db and convert it to epsg:31468 for further storage in a postgis database.
Currently my server job fails with
"ORACLE Reader: No exceptions match for SRID `314685783' was found -- determining coordinate system using Well Known Text"
Best answer by dollargis
OK, found
* https://knowledge.safe.com/articles/585/using-coordinate-systems-within-fme.html
* https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Coordinate_Systems/Workbench/coordinate_sys_custom_about.htm
* https://demos-safe-software.fmecloud.com/fmedatastreaming/Coordsys/Start.fmw?
Now I only need my projection guru's input to fill in the form ...
