FME Desktop 2018.1.01. on Windows Server 2012.
I started a translation at 1523 yesterday which simply reads point data from SQL Server Spatial and writes it to an ArcSDE layer. At 1821 STATRP lines started appearing in the log. And at the end I got 2 lines saying "Translation was SUCCESSFUL with 1 warning(s)..." instead of the usual 1 line.
Statistics are ticked in the translation options but I've never noticed this situation before. What is STATRP, and how is it different from STATS?
2019-06-17 18:21:30|9989.8| 2.5|INFORM|Transaction #3779 was successfully committed
2019-06-17 18:21:34|9993.1| 3.3|INFORM|Reading source feature # 3780000
2019-06-17 18:21:34|9993.1| 0.0|INFORM|Transaction #3780 was successfully committed
2019-06-17 18:21:36|9995.6| 2.5|INFORM|Transaction #3781 was successfully committed
2019-06-17 18:21:39|9998.1| 2.5|INFORM|Transaction #3782 was successfully committed
2019-06-17 18:21:40|9999.4| 1.3|INFORM|Reading source feature # 3782500
2019-06-17 18:21:42|10000.6| 1.2|STATRP|Reading source feature # 3783000
2019-06-17 18:21:42|10000.6| 1.2|INFORM|Transaction #3783 was successfully committed
2019-06-17 18:21:43|10001.9| 1.3|STATRP|Reading source feature # 3783500
2019-06-17 18:21:44|10003.2| 2.5|STATRP|Reading source feature # 3784000
2019-06-17 18:21:44|10003.2| 2.5|INFORM|Transaction #3784 was successfully committed
2019-06-17 18:21:45|10004.4| 1.3|STATRP|Reading source feature # 3784500
2019-06-17 18:21:47|10005.7| 2.5|STATRP|Reading source feature # 3785000
2019-06-17 18:21:47|10005.7| 2.5|INFORM|Reading source feature # 3785000
2019-06-17 18:21:47|10005.7| 0.0|INFORM|Transaction #3785 was successfully committed
2019-06-17 18:21:48|10007.0| 1.3|STATRP|Reading source feature # 3785500
2019-06-17 18:21:49|10008.2| 2.5|STATRP|Reading source feature # 3786000
2019-06-17 18:21:49|10008.2| 2.5|INFORM|Transaction #3786 was successfully committed
2019-06-17 19:07:01|12583.8| 0.0|STATS |==============================================================================
2019-06-17 19:07:01|12583.8| 0.0|STATS |Total Features Written 4795418
2019-06-17 19:07:01|12583.8| 0.0|STATS |=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
2019-06-17 19:07:01|12583.8| 0.0|INFORM|Translation was SUCCESSFUL with 1 warning(s) (4795418 feature(s) output)
2019-06-17 19:07:01|12583.8| 0.0|STATRP|Translation was SUCCESSFUL with 1 warning(s) (4795418 feature(s) output)
