Whats is the best way to connect to an IBM MQ 9.3 message broker from a workspace running as a stream on Fme Flow 2023? We need to be able to process several hundreds of messages/sec. I’ve done quite a lot of testing with the MQTT connector transformer and Mosquitto MQTT broker. Very fast and reliable. IMB MQ only supports AMQP 1.0 protocol and the question is if there is a connector transformer I can use for that? Fme Rabbit connector supports AMQP 0-9.
/Stefan Ljungstedt
FME Flow Stream connection to IBM MQ 9.3
