what transformers are used to detect changes?
solene01
Forum|alt.badge.img+3
Hello
I try to set up a processing chain to compare provider shape files and those of my database to integrate them into postgres database.
however I am not sure to use the right transform to detect errors in data.
I’m an idea taker if you have any =)
thank you
  • May 3, 2023
The ChangeDetector would be the obvious choice, at least as a starting point.
danminneyatsaf
Forum|alt.badge.img+12
Echoing what @david_r​ has mentioned, I highly recommend checking out our article on how to use the Change Detector transformer: https://community.safe.com/s/article/updating-databases-using-change-detection-to-set-f
Forum|alt.badge.img+49
In addition to the ChangeDetector the Matcher can be used as well.
Thank you for the article link sir.
