How can I pull Geometry data (CityGML) from an online database into my FME workspace for an adjustable selection area?
The mentioned database is available under the following url: https://www.opengeodata.nrw.de/produkte/geobasis/3dg/lod2_gml/lod2_gml/ . According to a very brief documentation the database is provided as an ATOM Download-Feed. But unfortunately I don't understand how to handle it in FME and will appreciate any advise.
Best regards
Alex
Best answer by daveatsafe
Hi @mralex007​,
The LoD tiles are 1000m * 1000m, with the lower left corner specified in the tile name.
So the tile LoD2_32_280_5657_1_NW.gml would have its lower left at 280000, 5657000 in the coordinate system EPSG:25832.
The easiest way to get the data is to reproject your selection polygon to EPSG:25832 (if needed), scale it by 0.001, then round the coordinates to 0 decimal places. Extract the coordinates as a list - each unique coordinate will specify a tile to download to cover the original selection.
You can use the FeatureReader transformer to read a CityGML dataset directly from the URL of the tile. You will need to set the reader parameter Reader Driven by CityGML Schema to No, however.
daveatsafe
Forum|alt.badge.img+19
Hi @mralex007​,
daveatsafe wrote:
Hi @mralex007​,
Thank you very much for the helpful answer! My model is finally working.
